jolab
Hi,
Maybe someone has had the same problem...
I have had IB for 6+ years now. I have an external Omni antennae and everything else is the same as it has been working for years. Its the old desktop modem (white). I have max signal and can download @ max speed usually.
Symptoms : Iburst is fine and then suddenly, the data light (green) starts flashing (as if lots of bandwitdh is being used - there isn't). everything is dead - no access to internet at all (not slow - dead) after a few minutes of this the iburst router resets itself - All signal light go out, data light turns orange, and then its back up.
This used to happen once every few months but in the last month or 2 this is happening 20-30 times a day.
Its no longer workable.
Rooi, maybe you can tell me if its the router, base station or a problem with the network.
GPS : S33 59.458 E18 28.842
Johan
Johan
