Problem with Suitcase on new Macbook Pro with 10.6.1
soundbase
I am having a problem with Freehand, and Suitcase with my new Macbook pro.
Suitcase opens automatically on startup. When I open Freehand, the spinning ball comes up. Only when I quit Suitcase, does Freehaad open correctly. Does anyone know what could be causing this. My Macbook has 10.6.1 installed
Here is the error message I get:
Date/Time: 2009-11-09 11:33:49 +0200
OS Version: 10.6 (Build 10A432)
Architecture: x86_64
Report Version: 6
Command: Suitcase
Path: /Applications/Extensis Suitcase X1/Extensis Suitcase X1.app/Contents/MacOS/Extensis Suitcase
Rosetta: Yes
Version: 11.0.0E (11.0.0)
Parent: launchd 96
PID: 615
Event: hang
Duration: 4.53s (sampling started after 2 seconds)
Steps: 25 (100ms sampling interval)
Pageins: 0
Pageouts: 0
Process: Extensis Suitcase 615
Rosetta: Yes
UID: 501
Process: Acrobat 301
Path: /Applications/Adobe Acrobat 8 Professional/Adobe Acrobat Professional.app/Contents/MacOS/Acrobat
UID: 501
Process: Adobe Photoshop CS 169
Path: /Applications/Adobe Photoshop CS/Adobe Photoshop CS.app/Contents/MacOSClassic/Adobe Photoshop CS
Rosetta: Yes
UID: 501
Process: AirPort Base Station Agent 118
Path: /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
UID: 501
Thread 9da37a8 DispatchQueue 1
User stack:
25 ??? (in AirPort Base Station Agent + 5344) 0x1000014e0
25 ??? (in AirPort Base Station Agent + 70666) 0x10001140a
25 CFRunLoopRun + 70 (in CoreFoundation) 0x7fff86864dc6
25 CFRunLoopRunSpecific + 575 (in CoreFoundation) 0x7fff8686503f
25 __CFRunLoopRun + 2002 (in CoreFoundation) 0x7fff86865ce2
25 mach_msg_trap + 10 (in libSystem.B.dylib) 0x7fff873b4efa
Kernel stack:
25 ipc_mqueue_receive_continue + 0 0x2104e0
Thread 9ddab7c DispatchQueue 2
User stack:
25 start_wqthread + 13 (in libSystem.B.dylib) 0x7fff873ceb1d
25 _pthread_wqthread + 353 (in libSystem.B.dylib) 0x7fff873cec80
25 _dispatch_worker_thread2 + 244 (in libSystem.B.dylib) 0x7fff873cf34e
25 _dispatch_queue_invoke + 185 (in libSystem.B.dylib) 0x7fff873cf824
25 kevent + 10 (in libSystem.B.dylib) 0x7fff873cdc7e
Kernel stack:
25 kevent + 97 0x470677
Thread 9de83d4
User stack:
25 thread_start + 13 (in libSystem.B.dylib) 0x7fff873edf21
25 _pthread_start + 331 (in libSystem.B.dylib) 0x7fff873ee06e
25 select$DARWIN_EXTSN + 10 (in libSystem.B.dylib) 0x7fff873f8aae
Kernel stack:
25 sleep + 52 0x486ec5
Binary Images:
0x100000000 - 0x100016fff com.apple.AirPortBaseStationAgent 1.5.4 (154.2) <73DF13C1-AF86-EC2C-9056-8D1946E607CF> /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
0x7fff8681a000 - 0x7fff8698dfef com.apple.CoreFoundation 6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff873b4000 - 0x7fff87573fe7 libSystem.B.dylib ??? (???) <1AABDC4B-CBAE-F40C-405C-DAE785959F57> /usr/lib/libSystem.B.dylib
Process: AppleSpell 224
Path: /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
UID: 501
Thread 9ce0000 DispatchQueue 1
User stack:
25 ??? (in AppleSpell + 5976) 0x100001758
25 ??? (in AppleSpell + 6632) 0x1000019e8
25 -NSSpellServer run + 72 (in Foundation) 0x7fff8573b7f2
Kernel stack:
Freehand is actually still great software for drawing. But suitcase has been totally supserseded - get fontxplorer pro or fontcase.
The problem with FH is that it is going to launch in Rosetta and Adobe has long since shelved it - mothballed deluxe.
Why are you using Suitcase? I really do prefer Linotype FontExplorer.
Anything that FH can do, Illustrator can do better. I know in the agency setup guys like FH even for layout. Truth be told, if I start FH now the only thing I will remember is the QUIT function....
On review, I see that:
PID: 615 (Suitcase in Rosetta)
Event: hang
-and then-
Rosetta: Yes
You have PPC Suitcase and an early CS (1 I presume) both running in Rosetta. The Suitcase process hangs. Does suitcase work in Rosetta on its own? Does it work with Photoshop? Any chance of bringing Suitcase into Intel?
Also, why are you using Suitcase?
