Hi there ...
I've received my Neotel router 3 days ago, but now I've got the following problem:
I've got a HP notebook that I want to connect to it.
On the notebook, I've got Windows XP SP2, as well as Ubuntu Linux.
When I use Linux, I can connect to the router with wifi & ethernet, without any problem ...I get a DHCP IP, and woalla!... connection done and I'm on my way ...
NOW ...the problem starts when I try and use XP ...
When I connect to it with ethernet, then everything works fine ...I get a DHCP IP address asigned, and whoap! ...internet works ...
When I try to use wifi, it's a whole different ballgame ... I connect to the wifi connection without a problem ...authentication is done, but then it looks like I have difficulty getting a DHCP IP assinged to the interface ...
I've tried using static IP's ...again ...WIFI gets connected, authentication is done, and it actually tells me "I'm connected ...
When I do ipconfig, I can see the interface has got the right IP ....but from there I can't do anything ...I can't ping the wifi router at all ...
Does anyone have any idea what might cause this????
Like I said ....on Linux it works fine, so it must be something todo with XP SP2 maybe?? ...Oh ...to through an extra spanner in the wheel ...tried my wife's notebook with Vista ....same thing ...connects, but can't get IP address assigned ...
