Problem with UTD through usb
darkelf
Parow North
Hi everyone
Did some one else had a problem before where with a utd modem not working through usb?
I am unable to use the usb cable for each time I do it doesn't get detected by the pc and when I check under the Device Manager for the iBurst Terminal, it has an error mark next to it and the error is: This device cannot start. (Code 10)
Can anyone advise me on this? I've checked the services list, but can't see anything wrong.
It works fine through Ethernet cable though, but its frustrating not being able to see the signal strength through the iBurst Utility.
actually, you should be able to check signal strength through ethernet.
Well, I never could do it through the iBurst utility installed along with the driver.
It will probably work through the telnet method or that iconnect thing I've seen on this forum.
If some one can please assist me with this. I need to know whether it might be my pc (tried on 2 pc's now and both with the same result) or whether it might be a hardware fault with my UTD Modem.
Thanks in advance for your efforts.
Are you running the latest firmware for that particular device? Check with the iBurst site.
