Dan The Man
- Apr 24, 2006
Hi all,
i did run a search to see if this has come up before - if i missed the thread then i apologise
My problem:
Up until last night i've been able to connect to the UTD through my on board lan port without any worries....
then from about 11pm and beyond ill switch the utd on it will create a local connection between the utd and my pc, but when i try and connect iburst it just freezes on the connecting through wan mini port window. then get error saying unable to reach remote computer bla bla ( its never done that before)
so i figured great my on board lan is messed up, so i whip out a network card plug & install. but when i connect the utd to the new network card it doesnt created a local connection at all
so quite obviously i wont be able to connect iburst through it.
i know i can just use the usb, but i prefer the ethernet way and really would like to resolve this
any idea why my on board has frozen or why the utd and network card aren't talking to each other ??
any advice will be much appreciated
thanks Dan
My problem:
thanks Dan
