Problems Installing HSDPA Card
B.Gil
Hi V3G im having problems installing a new merlin 740 card on a PC, Installation of software is correct, when creating a profile insert the data card into a PC card adapter Windows pnp detects the hardware but is unable to find device drivers could you assist me with this thank you
Merlin 740 Data Card
PC Card Adapter Ricoh Chipset
VMC V.7
Windows XP SP1
ArminM said:
did you reboot after the initial install?
I inserted a Merlin u630 Data card and it worked immediately with no prblems and yes i did reboot after install. According to 155 data consultants they have a problem when they use the E-Lan card that it does not even detect the new hsdpa card, My PC card adapter works fine and does detect the input of a pcmcia card but unable to find drivers getting an error code 28. Previously with the earlier cards two files were needed to complete the installation mf.inf and mf.pnf but in this case i tried to manually search for drivers in the wiindows inf and system32 folders but no luck.
has any of the fellow forumites have problems installing the merlin 740 data card on a desktop machine
