Problems - What's wrong with this?
saffakanera
Pinging 196.38.73.182 with 32 bytes of data:
Reply from 196.38.73.182: bytes=32 time=12ms TTL=247
Reply from 196.38.73.182: bytes=32 time=13ms TTL=247
Request timed out.
Reply from 196.38.73.182: bytes=32 time=24ms TTL=247
Request timed out.
Reply from 196.38.73.182: bytes=32 time=14ms TTL=247
Reply from 196.38.73.182: bytes=32 time=22ms TTL=247
Reply from 196.38.73.182: bytes=32 time=30ms TTL=247
Switched ISPs, router, you think DSLAM not lekker? Or at least the port?
Need more info. Line stats, what ISP, what times.
Have you tried removing all things connected to the line and then pluging the router in directly.
