izakmarais
- Aug 26, 2008
Hi All,
I'm having trouble with my netgear DG834G(v4) ADSL router, updated to latest firmware. I have replaced it once already, but the new router does exactly the same. I would like to know
1) how many other people experienced similar problems?
2) can you suggest an alternative router? (stick with netgear or switch to linksys?)
The symptoms: after working hard for a while (maybe 30min-1h) the router loses line-sync and then the power light starts flashing green on and off. During this time I cannot even access the router, so something is seriously wrong. In the troubleshooting manual no mention is made of this behaviour; the DSL light may flash when acquiring lines sync, but the power light must either be solid green (on) or solid red (failed to boot). Sometimes, when I switch the router off for a while to cool down it works again.
Another peeve I have with the router is that, when switched to bridge mode (modem only mode) to allow multiple PPPoE connections, the router does not run a DHCP server any more. Also this mode does not appear to be well supported, since one must access a hidden page on the router to set it (" use http://192.168.0.1/mode.htm to switch modes. " from this thread)
The place I bought it only sell Netgear and Linksys, so I am thinking of trying Lynksys. Can someone confirm that the simlar priced Linksys router (probably WAG200G?) can do bridge mode? Are there other features of the netgear that I will miss on the Linksys?
Izak
Izak
