southafricanrob
- May 7, 2009
Hi guys - I need some quick advice - I am hosting a movie night at my cafe tomorrow and am struggling to get the setup working.
So far I have:
- Vivitek Projector (HDMI & VGA inputs)
- Logitech x530 5.1 system
- Raspberry Pi or WDTV as the media player.
The sound system is all wired into the roof etc and we use it to play music etc during the day from a desktop PC with a 5.1 sound card. The problem I am having is getting 5.1 sound form the media player to the speakers. Best I can do is to take stereo from the media player and use an adapter to play on the 5.1 - so effectively losing the surround sound option. This is pretty NB, firstly as its sounds good ;-) and secondly because the speakers are in odd places and so I need to be able to tweak the individual levels up and down a bit.
So short of finding some sort Optical to PC 5.1 converter my only option is to use the cafe desktop to play the movie. Sound will work great but it means running a 15m VGA cable to the projector.
So I guess my question is:
Will I end up with a really crap low quality pic using a VGA cable of this length? (My display card is the built in Intelq35 chipset with VGA and DVI ports only)
So far I have:
