I'm hoping someone can point me in the right direction. I've had a Proline 2000VA Line Interactive UPS for the past 4 years, and for the most part, it has done its job. It basically powers a small server and an ADSL modem and separate router for about 1-2 hours, which is great (and a lot longer if I turn off the server). Recently, however, I've found it only lasts about 1 minute before turning off when the power goes, which is happening more frequently in my area. From what I understand, this suggests that the battery needs replacing, however, I'm not sure how to go about it. I don't really want to open it up, and would rather get someone else to do it (mortal fear from all these stories of UPS' blowing up), but not sure whether I'd need to contact Proline (tried via their apparent "email support", but have been waiting 3 weeks now), or maybe I can do it through a local store which supplies batteries. I live in Pietermaritzburg, so I'm a bit isolated.
It would be nice to replace the item with something new, but the APC brands are far too expensive with this kind of capacity, and the alternative is just buying the same model again, which is R2k on Takealot.
Can anyone provide some guidance on what route to take. Are there any alternatives I should consider?
Thanks!
Thanks!
