How do I go about setting up my PS3 to play through a 5.1 Surround sound system. My PS3 is currently only connected to TV via HDMI cable
Rather go Optical to receiver. and HDMI straight to TV. Some receivers mess-up the HDMI tv signal in passthrough. Just my opinion.
And if you have more than 2 devices? There is usually only one optical and one coax port. Optical is not the way to go. Invest upfront in a decent AV receiver that does HDMI repeating (or audio return), even if it means that you can only afford the start with a set of stereo floor standing speakers. Then save up for the surround speakers and sub. If your budget is around R10k, then you can even get everything in one go.
Optical is not the way to go. Invest upfront in a decent AV receiver that does HDMI repeating (or audio return), even if it means that you can only afford the start with a set of stereo floor standing speakers. Then save up for the surround speakers and sub. Don't go and make the mistake of buying a cheap receiver just because it'll support your current requirement, think about the future.
