PS3 Firmware 3.15
http://www.wonderwallweb.com/news/3474/firmware-315-change-log/
Seems like a coupla changes worth having... Lan data transfer? anyone know how this works?
It's to transfer your existing PS3 to a new PS3 assuming both still works fine1
LAN Data Transfer Utility
1. Turn both the current PS3 (A) and new PS3 (B) on and connect them with a LAN cable; PS3 (A) should be connected to the TV. Please note, firmware (v3.15) must be installed on both systems.
2. On the XMB of PS3 (A), scroll to the Settings category and select [System Settings] and then [Data Transfer Utility]
3. Follow the instructions on-screen and transfer data
4. After transferring the data, follow the instructions on-screen, and then connect PS3 (B) to the TV to view the XMB
5. If content that was downloaded from PlayStation Store was transferred as part of this operation, you must activate PS3 (B) before you can use the data. Log in to the PS3 system as the user who owns the content, and then select (PlayStation Network) > (Account Management) > (System Activation) to activate the system.
