ps3 wireless lag when playing pes2011
pleodon1
got a ps3 and using my wireless to play online (384kb line speed)..im playing pes2011 and thers a lag when i play!!:( if i use a network cable to my router from my ps3 would there be change in the performance??
Doubtful, but worth a try. Are there walls between your PS3 and the router?
Most likely you'll have to up your line speed to 1Mbps.
It all depends but i doubt thats your problem. I run a full 54mbps wirelesss network at home with no latency difference whatsoever compared to cable. It all depends wireless networks slow down when you copy files over it from pc to pc or device to device it can cause packet loss depending on your setup.
Someone on the network can download or something is updating or your ISP might be crap :P
play online
Most obvious answer is you're either playing against opponents overseas or your connection isn't fast enough.
Least likely answer is to do with your wireless network.
