Hectic
Good evening.
Recently my triangle, square and options button became unresponsive.
Yesterday I decided to open up the controller and cleaned the various buttons.
I assembled again and the buttons worked fine, but I noticed that the light bar didn't work anymore. It didn't bother me, so I left it that way. However I later discovered that the charging port didn't work.
Googled and found that the same 14 pin flat ribbon cable for the light bar also provides power to the charging port.
Opened up the controller and fixed the problem and closed up again.
The light was now on and the battery could charge.
A bit later I discovered that the light did not switched off when the controller was switched off.
Again I opened the controller and removed the cable.
This time I saw that the copper contact points were damaged. Some have lifted and were broken off and one contact point was bent at angle and was creating a short.
I tried snipping the broken tips off with a scissor, but there aren't enough of the contact points left to conduct, once inserted into the slot.
I saw that the cable is about $3 - 5 in the USA, but someone in Cape Town is selling the cable for R200.00.
Does anybody know where I can buy one cheaper or where I can buy a stripper tool for a 14 pin flat cable or any other method for stripping it without the relevant tool?
I saw someone mentioned acetone, but I still need a plastic backing for the contact in order to get it in the socket again.
Tldr:
Looking for a replacement 14 pin flat ribbon cable for the light bar / charging port or a method to strip the cable.
Thank you
Tldr:
Thank you
