PSP Card and Battery
f4ntom
Got hold of a second hand PSP the other day for my holidays (so close so close so close.. ). Problem is the stock battery is pathetic (3 hours) which I understand is normal. I hear one can purchase non-sony batteries that extend playing time dramatically; any battery packs that are particularly good?
And finally I have found the 1GB card I got with the PSP limiting (not enough space for Final Fantasy). I searched Prophecy and came across a 4gb for +-R300. Is this a good deal, preferrably I would like even more space than that but it gets pricey for 8gb and 16gb cards.
Any help would be appreciated :D
With my PSP 3000 i get way more than 3 hours (purely playing games). I am not 100% sure on the non Sony batteries but i have heard stories of batteries overheating and damaging the PSP, is it worth the risk?
And for memory i have a Dual Micro SD to Pro Duo converter. I have 2 x 8gb Micro SD cards in it so i get a full 16gb (well just below that).
Thanks alot guys. Never thought of getting a microsd converter. Will be checking them out.
Okay, decided to go for:
8GB card from MAKRO : R399
Analogue Button from PS-Shop: R50
Any useful PSP accessories? I notice the screen has a lot of glare.
