PSU size help with corsair 380t
Mahoza
I would like to buy a Corsair 380t case to move my current pc into however I have an antec hcg 850m psu and am not sure if it will fit. The corsair website says the case fits 180 mm psu but other websites say 160mm. My psu is 170mm. I know if you remove the hdd cage you can fit a bigger psu but I need the hdd cage for my 1 hdd.
i am going to say its a no go.. having a look at the build log https://youtu.be/vtKuWwRCPCY at 4:21 in you can see the space between the fitted psu which is 160mm and the hard drive cage.. pure eyeballing it, that looks like about a 1cm gap which will the push your psu against the cage.. now, you may be lucky if you flip the psu around to avoid the cables from interfering with the cage..
