Pylon UP5000 mount options
Adeptus Mechanicus
Here
I have 2 of these waiting to be installed. I see that one can mount these on the wall or get brackets that allow you to stack them on top of each other.
The former option creates complication due to the length of the battery and comms cables (mounting 2 side by side is a little too far)
The latter option leaves them a little more exposed than I'd like.
Are there any decent cabinet options out there that aren't like R10k+ and might allow for a 3rd battery to be added?
I have mine in this,
I'm using something like this...
Does this fit 2 of the 5000's? Is the spacing between batteries decent?
