As I am playing a MOGG I need to cut down on PL alot.
PL is most important.
Latency/Ping is important but anything <500 is livable.
I have noticed a significant change when I Attached the patch antenna.
<i><b>Prior to Antenna :</b>
3 Modem Lights, 15% signal.
<b>After Antenna :</b>
4 Modem Lights(5 Software), 21-27% Signal.
This change has actually made a big change in my gameplay as well.
Yes I know the fact that I see the green Lag lights in the game makes my mind believe all is well, and possibly all is not well...but those lights are green and im happy...(Contemplating painting green dots on my screen)</i>
So, if the Cantenna is better than a Patch, that Would mean I would Possibly get 30%+ signal.
Last Question....probably not....
That N-Female Connector that goes into the Actual Can, how important is that to the functioning of the Cantenna?
Maybe I should pour some Chivas into the can, Add some BBQ Pringles, shake it up well. Throw out contents, BUT not wash out, to keep the flavour. then Set it up, im sure the Signal must be hungry after travelling that far....who knows, maybe the signal brings friends...[
