scubasteve1
- Feb 2, 2012
Hi All
So I have a Rentech vm-3000 (3Kwh) inverter connected to my main supply. no panels.
then from there a breaker unit that connects to a lithium 2.5kwh lithium wall mounted 24V battery.
small setup purely just for wifi, tv and a few lights during outages.
so we had a power outage that lasted 2 days due to vandalism/sabotage on a substation in my area :-(.
anyways, the battery eventually ran down and the inverter switched off..
but since power back on.. inverter not coming back on. so not sure where the issue could be, the inverter or the battery. (been 'charging' for a few days now still no go)
waiting for the installers to come out to check.
however, i have done the following. if i disconnect the battery from the inverter.. my battery output is reading around 6v.. should read >24v - so yes its flat.
but.. the inverter has AC power coming in 220v all good. but my inverter DC output to the battery is fluctuating from between 6 and 22V constantly.. surely this is not normal?
is my inverter cooked perhaps? have the installers configured my inverter incorrectly perhaps to run the battery flat instead of shutdown at 20% perhaps?
Any ideas?
thanks in adv
Any ideas?
thanks in adv
