Questions regarding BuzyBuy!
mugikhan
Cape Town before December holidays.
So I just wanted to ask who is using them and if they are any good on the IS side?
Also it says that their capped accounts are fully unshaped and they offer 300GB + 300GB for R999...I know webafrica have a similar offering but they shape their accounts...So is it too good to be true?
Anyone that can shed any light onto this?
They are reselling IS and MTN accounts last time I used them. Since IS and MTN control the shaping you can expect their accounts to work exactly the same as any IS or MTN uncapped account. I have used both the MTN and IS accounts and the IS account is slightly better as the MTN account will be almost permanently shaped for the rest of the month once you hit a certain threshold. If you are happy with the restrictions that comes with an IS account, especially since they now relax the shaping just before midnight, then I would recommend getting a Incredible Connection account as it's much cheaper and gives you exactly the same performance and benefits as the Buzybuy ones.
I used them for 2 months quite some time ago.
They use IS bandwidth which for the most part ran great.
Then the stars dropped and things were not so great during business hours but flew after 5pm.
If you don't need your interwebs during business hours ever, then their just as good as any other IS account IMO.
