Quick T-SQL Help Please
Pho3nix
The Legend
On the toilet
Hi guys,
Haven't played with SQL in a minute and stuck on some logic.
[table="width: 500"]
[tr]
[td]Id[/td]
[td]Name[/td]
[td]Type[/td]
[/tr]
[tr]
[td]1[/td]
[td]Bob[/td]
[td]Positive[/td]
[/tr]
[tr]
[td]2[/td]
[td]Bob[/td]
[td]Positive[/td]
[/tr]
[tr]
[td]3[/td]
[td]Bob[/td]
[td]Negative[/td]
[/tr]
[/table]
I have the above table and I'm looking to set the type to Positive. How would I do this?
output :
BobPositive
Code is actually a little more complex and trying to explain as best I can :o
EDIT : The output above with the three bobs is a result set from another query. I need to count the positives and negatives from that result set and only return the one that comes up the most.
Code:
up[B]da[/B]te [table_name]
s[B]e[/B]t type = 'positive'
w[B]her[/B]e id = 3
fml that was difficuilt to post, as giving the answer gets you banned from the site for attempt at sql injection attacks.
declare @cmd nvarchar(1000)
set @cmd = reverse('''boB'' = eman erehw ''evitisop'' = epyt tes elbat etadpu');
exec (@cmd)
exec (@cmd)
side note, based on the table above, it will make all Bob's positive. just a thought. rather update using the pK
what is injection for, if not for mischief :D, though, he said he wanted bob positive
Omg lol I meant from a select, as a grouping of sorts.
oh, lol, imo easiest is to make a common table expression, and then update that, though its not standard.
with x as (select statement) update x ....
From the OP he wants all bob's updated
This is probably the real reason he is posting the question though
I see how the initial post was worded and how it sounds that way. :| Will update
case statement.
in your select.
sum( case
when type = "positive" then 1
ELSE 0) as poscount,
sum( case
when type = "negative" then 1
ELSE 0) as negcount,
from blah blah
that will return the counts as 2 fields.
now select from that result set the greater number between the two.
Asuming your table name is results
Code:
select x.name, x.positives, x.negatives,
case when x.Positives > x.Negatives then 'Positive' else 'Negative' end as Final
from
select distinct r.name,
(select count(*) from results r2 where r2.name = r.name and r2.type = 'Positive') as Positives,
(select count(*) from results r2 where r2.name = r.name and r2.type ='Negative') as Negatives
from results r
) x
pardon the lack of formatting
You guys should crack a T-SQL book once in a while ;)
Code:
select Name, Type from [YourTable]
group by Name,Type
Having count(case when Type = 'Positive' then 1 end) > count(case when Type='Negative' then 1 end)
Code:
from
from results r
) x
Way too complicated and unnecessary when you could just using Group By/Having
I noticed this with a lot of guys learning about nested table selects that they all of a sudden use it everywhere. At scale, it will suck balls trying to beg the server gods for forgiveness in your long-running query causing issues
case statement.
in your select.
sum( case
sum( case
from blah blah
doesn't work
blah blah blah outside query
Code:
(SELECT
						CASE
							WHEN SUM(c.PosCount) > SUM(c.PosCount) THEN 'Positive'
							WHEN SUM(c.PosCount) < SUM(c.PosCount) THEN 'Negative'
						END AS Type
					 FROM calculate c
					 WHERE c.Id = so.Id
