Quickest method of copying a file from a PC using wifi?
  • Thread starter Thread starter Fudzy
  • Start date Start date
F
Fudzy
Guest
Busy using astro explorer but it's taking forever, is there a quicker method of copying a file from a Windows share wirelessly? I could download the file faster!
I use ES explorer, give it a try and see if the speeds are any better, but generally I've noticed the wifi speeds are slow when copying
i use ES explorer on my phone to copy from my network, but if you want to dump a few mp3's or other files quickly, check out Airdroid.
another option is running hfs ,, (http file share) then you can browse your files through any web browser on your phone.
if everything is still slow, then look at buying a new AP (+- R160 at www.scoop.co.za) or lifting it higher or something to increase the signal :P
Can you copy to a flash drive then use an OTG cable? That's quickest for me, besides plugging in via USB cable. How come you're limited to wireless?
Out of laziness :p
Wi-Fi 802.11 a/b/g/n - thinking the last two speeds are a lie.
