Quiet Case Fans in bulk
Tarzan
Hello all,
I am looking for a place to buy quite case fans in bulk (online if possible). A 5/10/20 pack would be fine. I replace a coulpe of them a year and buying one one is a little expensive. I need 90mm and 120mm fans. Any ideas?
Thanks,
Tarzan
a couple of them a year????
do you buy the cheapest fans? or even more importantly . . . do you ever bother to clean them? a clean fan is a happy fan. lol
I have 4 pcs as home and 10 at my office. I hate a loud pc, so I change them when it gets loud. A fan lasts 2-3 years.
120mm = Zalman ZM-F3, right up there with the best, and best of all seriously cheap, round R65-R70
Okay why not go the watercooling way?
All 14 of them? Maybe I can hook a couple of them to the koi pond lol.
What fans (makes) are you looking at?
I can get you pricing but as you can imagine, there are alot of makes out.
I normally buy the vizo super muffle fans, but any tipe of quiet case fans will do. Sometimes I change the psu's fan also with one.
Thanks, I look into it. That is cheap for zalman.
