Radeon HD 6800 issues / Quake 4
Merlin
Cape Town, South Africa
Hi all,
I am not a Gamer per se.
I'm currently playing Quake 4 and it's the first game I've played in as long as I can remember.
In December I installed a new Radeon HD 6800.
My monitor is a Samsung 24' WS.
They are connected via HDMI.
OS: XP 32
I'm not clued up on this stuff, but I'm told that I have a pretty potent graphics card. Before you ask, I laid out the cash because I use my PC as a media centre and I didn't want to have to upgrade in six months again.
When I max' out the graphics settings in Quake 4 and restart the app', it gives me an error and resets everything to lower settings.
I have Googled this, but found nothing concrete in terms of a solution.
I've uninstalled and reinstalled the drivers [latest now].
Have any of you encountered this issue, and if so, how did you resolve it?
Thanks.
Easy solution; don't max out everything :)
Also it would if we knew what the error message states.
Ola,
This card should run this game on max' without breaking a sweat.
"There was an error with the display settings, safe defaults have been selected"
Thanks.
http://support.amd.com/us/kbarticles/Pages/AMDCatalyst111ReleaseNotes.aspx
According to this it may be the new batch of drivers causing the issue,however is your quake 4 fully patched up ? That might be causing the issue, Same applies to your windows you should try upgrade to service pack 3 atleast for the security reasons,although if you want maxed settings why not try downloading a extreme high quality config and place it directly into your games directory.
My 2 cents peace out.
Hi DM,
Thanks for that link.
The in-game patch updater says I have the latest version.
I've just reinstalled and tried updating again. Same thing.
My OS is 100% patched.
I'll try the config' idea. Thank you.
Problem solved.
I downloaded the entire Point update last night.
It's now working. What a difference! :D
I don't know wtF the in-game updater said it was patched.
Thanks for your help everyone. :)
Problem solved.
Anytime Thats what forums are for:P
