radiator leaking small crack on plastic side how to fix ?
Just replace it before it leaves you in hot water.
No seriously, do not fix it. Replace.
This^ Radiators are not as expensive as you would think I got one for a 6cylinder BMW from the agent a few years back for under R1000.00
Raw egg if you are in a emergency...
That's a back in the day fix does it still work on the newer radiators without any damage? also that's if the core leaks not the housing itself?
Pratley's putty (should be available at most hardware stores, incl Game, Makro) should work. You can use the quick setting one...
Nonetheless, as advised, replace it at the soonest
