Wowgasm
Hi there,
I hope this is under the right section.
I just bought a brand new HP ML350 G6 server with 4 1TB drives.
I've installed the drives with Windows 2008 std 32-bit with raid 5.
For some reason, The computer recognizes the 2.7 TB which is fine, but 700GB of that 2.7TB is unusable. I cannot partition it, I cannot access it, nothing nada. Is this normal? Or did I do something wrong when I set up the array?
I mailed HP but no reply yet and I'm desperate here.
Thanks alot in advanced
