Rain Ethernet Cable
xodosman123
Hi all My friend Got rain and started having drops on Ethernet.
After Testing it was found that pin 1 on the cable was not good.
Changed the Ethernet cable not it works fine.
I don't think that that cable is of such a good quality.
If anyone has the same type of problem check the Ethernet Cable Between the Power supply and the Rain 5G Router.
I tested the fault with a Ethernet Cable tester.
Lata...
