Rain LTE-A/LTE
Dareno
Our new house is in an area without fibre, and the adsl has ben lifted by Telkom. Our house uses a lot of data, so we need an uncapped solution. While I realise right now, the available solutions will not be perfect, we do require some solution. The area of our property, the Rain LTE-A coverage literally touches the back of my new property. But will this be enough? Will our experience by decent if we attach the aerial in that area? Or am I in for pain? If I am that close to the 5G signal, will my 4G experience be better? Or is it trial and error? Any info will be appreciated.
Hi @Dareno
Please PM your address I will check coverage and advise you accordingly.
You might be ok with a directional CPE like the Huawei B2338 or antenna like the XPOL-6. It would be best to do a site survey first and test. Can you see any towers from your house?
