RAM upgrade problem
VBot
I bought 4GB ram (DDR2) (Corsair 2x2GB Kit) for my Dell Inspiron 1525 but both of them won't work at the same time.
When I install one module (in either slot) it works fine but when both are in I get a blue screen of death and the laptop reboots.
I've already updated BIOS but the problem persists. Is it a problem with my laptop or the ram?
Thanks NomNom
I ran memtest on both sticks and there were no errors.
Here are the error logs.
- System
- Provider
[ Name] Microsoft-Windows-Diagnostics-Performance
[ Guid] {cfc18ec0-96b1-4eba-961b-622caee05b0a}
EventID 200
Version 1
Level 3
Task 4007
Opcode 40
Keywords 0x8000000000010000
- TimeCreated
[ SystemTime] 2011-03-27T20:05:49.165Z
EventRecordID 9033
- Correlation
[ ActivityID] {00000000-9B8C-0001-B250-B607BAECCB01}
- Execution
[ ProcessID] 1036
[ ThreadID] 2716
Channel Microsoft-Windows-Diagnostics-Performance/Operational
Computer - PC
- Security
[ UserID] S-1-5-19
- EventData
ShutdownTsVersion 1
ShutdownStartTime 2011-03-27T19:47:41.034Z
ShutdownEndTime 2011-03-27T19:48:07.048Z
ShutdownTime 26013
ShutdownUserSessionTime 4173
ShutdownUserPolicyTime 215
ShutdownUserProfilesTime 485
ShutdownSystemSessionsTime 20374
ShutdownPreShutdownNotificationsTime 124
ShutdownServicesTime 20000
ShutdownKernelTime 1465
ShutdownRootCauseStepImprovementBits 0
ShutdownRootCauseGradualImprovementBits 0
ShutdownRootCauseStepDegradationBits 0
ShutdownRootCauseGradualDegradationBits 0
ShutdownIsDegradation false
ShutdownTimeChange 0
- System
- Provider
EventID 100
Version 1
Level 2
Task 4002
Opcode 34
- TimeCreated
[ SystemTime] 2011-03-27T20:05:55.062Z
EventRecordID 9034
- Correlation
[ ActivityID] {00000000-9B8C-0001-B350-B607BAECCB01}
- Execution
[ ProcessID] 1036
[ ThreadID] 2740
Computer -PC
- Security
[ UserID] S-1-5-19
- EventData
BootTsVersion 2
BootStartTime 2011-03-27T20:03:24.765Z
BootEndTime 2011-03-27T20:05:47.574Z
SystemBootInstance 115
UserBootInstance 114
BootTime 69720
MainPathBootTime 30720
BootKernelInitTime 32
BootDriverInitTime 5067
BootDevicesInitTime 9609
BootPrefetchInitTime 62954
BootPrefetchBytes 443432960
BootAutoChkTime 0
BootSmssInitTime 8175
BootCriticalServicesInitTime 1499
BootUserProfileProcessingTime 727
BootMachineProfileProcessingTime 839
BootExplorerInitTime 2863
BootNumStartupApps 13
BootPostBootTime 39000
BootIsRebootAfterInstall false
BootRootCauseStepImprovementBits 0
BootRootCauseGradualImprovementBits 0
BootRootCauseStepDegradationBits 0
BootRootCauseGradualDegradationBits 0
BootIsDegradation false
BootIsStepDegradation false
BootIsGradualDegradation false
BootImprovementDelta 0
BootDegradationDelta 0
BootIsRootCauseIdentified false
It could also be a timing/voltage issue, but I'm not sure if you can adjust those values in your laptop's BIOS, because I can't with my Dell Inspiron 9400.
IIRC, memtest x86 would report the latencies of the memory. CPU-z will definitely report the timings & voltages of the RAM.
Cheers Panda.
This is what I get from CPUZ
