Random BSODS again, Help
The Philosopher
Code:
DATE	BUG CHECK STRING	BUF CHECK CODE
2011/02/14 08:37	DRIVER_IRQL_NOT_LESS_OR_EQUAL	0x000000d1
2011/02/13 20:54	DRIVER_VERIFIER_DETECTED_VIOLATION	0x000000c4
2011/02/13 20:24	DRIVER_VERIFIER_DETECTED_VIOLATION	0x000000c4
2011/02/13 19:23	DRIVER_VERIFIER_DETECTED_VIOLATION	0x000000c4
2011/02/13 19:21	DRIVER_VERIFIER_DETECTED_VIOLATION	0x000000c4
2011/02/11 19:37	DRIVER_VERIFIER_IOMANAGER_VIOLATION	0x000000c9
2011/02/11 18:20	DRIVER_VERIFIER_DETECTED_VIOLATION	0x000000c4
2011/02/11 07:17	DRIVER_IRQL_NOT_LESS_OR_EQUAL	0x000000d1
2011/02/10 07:34	SYSTEM_THREAD_EXCEPTION_NOT_HANDLED	0x1000007e
2011/02/09 20:01	KERNEL_MODE_EXCEPTION_NOT_HANDLED	0x1000008e
2011/02/08 18:19	KERNEL_MODE_EXCEPTION_NOT_HANDLED	0x1000008e
2011/02/08 07:19	NTFS_FILE_SYSTEM	0x00000024
2011/02/04 07:26	NTFS_FILE_SYSTEM	0x00000024
2011/01/29 19:34	DRIVER_IRQL_NOT_LESS_OR_EQUAL	0x000000d1
2011/01/29 12:27	KERNEL_MODE_EXCEPTION_NOT_HANDLED	0x1000008e
2011/01/20 07:57	PAGE_FAULT_IN_NONPAGED_AREA	0x00000050
2011/01/18 14:31	DRIVER_IRQL_NOT_LESS_OR_EQUAL	0x000000d1
2011/01/16 00:02	KERNEL_MODE_EXCEPTION_NOT_HANDLED	0x1000008e
2011/01/14 19:06	SYSTEM_THREAD_EXCEPTION_NOT_HANDLED	0x1000007e
2011/01/13 08:12	KERNEL_MODE_EXCEPTION_NOT_HANDLED	0x1000008e
2011/01/12 23:50	KERNEL_MODE_EXCEPTION_NOT_HANDLED	0x1000008e
2011/01/12 19:50	PAGE_FAULT_IN_NONPAGED_AREA	0x00000050
Code:
PAR 1	PAR 2	PAR 3 	PAR 4	CAUSED BY	ADDRESS	FILE DESCRIPTION
0x8d2c2010	0x00000002	0x00000000	0x852b36f2	ataport.SYS	ataport.SYS+36f2	ATAPI Driver Extension
0x00000000	0x00000000	0x00000000	0x00000000	afd.sys	afd.sys+405ca	Ancillary Function Driver for WinSock
0x00000007	0x9ab34340	0x9a626f68	0x00000000	pbfilter.sys	pbfilter.sys+2340
0x0000000c	0x00000002	0x00000000	0x892abbfb	tcpip.sys	tcpip.sys+27bfb	TCP/IP Driver
0xc0000005	0x8f72cf79	0x826865e4	0x826861c0	nvlddmkm.sys	nvlddmkm.sys+126f79	NVIDIA Windows Kernel Mode Driver, Version 260.89
0xc0000005	0x8f59597f	0xa4ed53f8	0x00000000	nvlddmkm.sys	nvlddmkm.sys+16797f	NVIDIA Windows Kernel Mode Driver, Version 260.89
0xc0000005	0x8f55252a	0x9db05870	0x00000000	ks.sys	ks.sys+352a	Kernel CSA Library
0x001904fb	0xa361f738	0xa361f310	0x82e2acf4	Ntfs.sys	Ntfs.sys+14221	NT File System Driver
0x001904fb	0x96e63b5c	0x96e63740	0x890a475a	Ntfs.sys	Ntfs.sys+9375a	NT File System Driver
0x00000018	0x00000002	0x00000000	0x8925a7f6	tcpip.sys	tcpip.sys+427f6	TCP/IP Driver
0xc000001d	0x822b415e	0x8b0f6c00	0x00000000	win32k.sys	win32k.sys+9415e	Multi-User Win32 Driver
0xf1e24301	0x00000008	0xf1e24301	0x00000002	nvlddmkm.sys	nvlddmkm.sys+15b0ab	NVIDIA Windows Kernel Mode Driver, Version 260.89
0x00000013	0x00000002	0x00000000	0x892797f6	tcpip.sys	tcpip.sys+427f6	TCP/IP Driver
0xc000001d	0x8ed00c6e	0x96a0b6bc	0x00000000	dxgkrnl.sys	dxgkrnl.sys+7ac6e	DirectX Graphics Kernel
0xc0000005	0x8ec8b5ee	0x8c85f658	0x8c85f230	dxgkrnl.sys	dxgkrnl.sys+1d5ee	DirectX Graphics Kernel
0xc0000005	0x82cbef3b	0xa38d881c	0x00000000	halmacpi.dll	halmacpi.dll+3900	Hardware Abstraction Layer DLL
0xc0000005	0xfe147b53	0x9ae73b2c	0x00000000	win32k.sys	win32k.sys+bdb82	Multi-User Win32 Driver
0x9dbc0000	0x00000008	0x9dbbffff	0x00000000	ntkrnlpa.exe	ntkrnlpa.exe+85903	NT Kernel & System
As you can see my bsod's started on 12 of jan. I got internet on the 9 or so. So it started as i started using the internet. However apart from the driver verified induced crashes, the crashes are different most of the time.
When using verifier, it crashes afd.sys with c4 error code all most always. I have read alot and it seems that it has to do with the internet and most of the time ethernet adapter drivers, which seems cogent because it started just after i got internet at my new place. However, i got the latest drivers for my on board realtek 1gb ethernet port which is from gigabyte, GA-P35-DS3L Rev2.0. It was also suggested to uncheck power down ethernet card when idle. However it crashed when i was a work today. Usually crashes after about 5 or six hours of being on. It has only crashed once when i was using it. Otherwise it would crash in the middle of the night or while I was at work. This is getting very frustrating. sometime it would only crash after 2 to 3 days.
I got win 7, E6850, 8800GT, Transcend axe ram 1066 (crap cant even run it at latency it is advertised as). I also go the latest BIOS F9.
I can upload my mini dumps, but how do i do that?
pbfilter.sys is the only one in there that is not a built-in Windows driver (except for the nVidias, although they shouldn't cause network problems). I would try to uninstall peerblock and see if that fixes the BSODs.
Otherwise, download Debugging tools for Windows and open the crash dump with Windbg. Set up symbols to point to MS symbol server.
The command "!analyze -v" will usually indicate which driver is causing the problem. See here for a tutorial.
I didnt have a crash for a week, I didnt change anything, but now crashes started again and I got 2 xd1 and 2 x8e's. Okay I am going to uninstall peerblock and see how that works, however i havent used it for 2 weeks now.
okay i followed the toturial, but it doesnt seem to help me much. My crashes keep changing, it is rarely the same driver causing the crash. Is it possible that it is a hardware piece that is busy failing?
I RAN MEMTEST for the first time last night, and this morning i found that there were 999999 errors on the one stick. and on the other there were about 30. It had done 1 pass. Also on test 8 it kept rolling over from 0 to 32000 errors, i know that that number is the limit for integers. it was as though memtest had crashed. i am only running one stick in it today while i am at work.
seems like it could be faulty intermittent ram. will let you know the results of individual tests. also what other info do you require from the memtest?
Okay I ran individual ram tests and the one stick passed 10 passes with no errors and the other stick passed only 1 pass after 10 hours and racked up 99999999 errors and basically crashed memtest. So i have a faulty stick of ram. It is transcend gaming ram and comes with a lifetime warranty. So I will take it in tm. Hopefully my random crashing will end now.
there are more twists in the tale than in a twizler! so just before i decide to take the ram in to replace i decide to test it in another slot to make sure. I did 43 passes over 8 hours with not 1 error. so i conclude that that one ram slot is faulty!
So I moved my dual channel ram to the other slots and will test all over gain!. hopefully this will resolve my bsod issues.
btw, while i have been waiting i was only the one stick of ram and i had no bsods also other programs were working better with no errors. however my pc was super slow with only 1gb of ram. running win 7.
