Rare Science Books and Manuscripts
Nanfeishen
Neither Here Nor There
Discovered this site dedicated to old scientific journals etc, with some really unbelievable archival literature :
http://lhldigital.lindahall.org/
Example : - early atronomical works, click on image of a manuscript for entire contents
http://lhldigital.lindahall.org/cdm4/browse.php?CISOROOT=/astro_atlas
List of the Collection:
http://lhldigital.lindahall.org/cdm4/about.php
Online Exhibitions
http://www.lindahall.org/events_exhib/exhibit/index.shtml
Must be one of the best archives i have ever found
Wow! Charles Babbage's Calculating Machine
http://lhldigital.lindahall.org/cdm4/document.php?CISOROOT=/eng_tech&CISOPTR=9&REC=1
Babbage's machines were among the first mechanical computers, although they were not actually completed, largely because of funding problems and personality issues. He directed the building of some steam-powered machines that achieved some success, suggesting that calculations could be mechanized. Although Babbage's machines were mechanical and unwieldy, their basic architecture was very similar to a modern computer. The data and program memory were separated, operation was instruction based, the control unit could make conditional jumps and the machine had a separate I/O unit. For more than ten years he received government funding for his project, which amounted to £17,000.00, but eventually the Treasury lost confidence in Babbage.[25]
The Difference Engine and the achievement of designing the world's first programmable machine was what got me interested in programming in the first place. So awesome.
"The whole of arithmetic now appeared within the grasp of mechanism. " - Charles Babbage
This may or may not be known, but the first programmable computer was developed not by Charles Babbage but by Konrad Zuse.
The Difference Engine was indeed a programmable machine by any definition I can think of and it was designed decades before Zuse was even born.
Zuse built the first fully automatic program-controlled machine, it was an incredible feat and he deserves recognition for it but Babbage designed the first programmable machine.
Isn't the difference engine just a calculator?
Sort of. The machine had a bunch of columns and you programmed it by setting initial values for the columns. Then you rotated a crank to have it produce results.
Up until then machines worked in one particular way with the mechanism performing only one operation. Inputs that always produced the same output. Babbage was the first to create a machine that allowed you to input values (program it in a very basic language of columns) and have it produce different outputs. It may have been simple but it was definitely the first programmable machine.
