MajorPanic
Hi all,
I have a B+ running XBMC via Openelec. My problem is that under the output resolution settings I can only find 1080i and not 1080p.
I am using a 1.3a HDMI cable running into a Samsung receiver which then outputs to my Samsung 46" LED.
Using the same cable configuration I can get full 1080p from my XBox 360.
The Pi is powered by a cellphone charger rated at 5V =1A.
Any ideas as to what I can do to get to 1080p?
I also have a second issue in that the TV will randomly go blank for 1-2 seconds before restoring the signal from the Pi (again, does not happen with the XBox).
Appreciate any suggestions
