Really frustrating router problem
Hi all
I wonder if anyone here has an idea what to do about my problem. I've had a Mecer +2 router for about two years now. About a week ago it started to drop sync, and I'd have to reboot. It would last a while then drop sync again. I thought it was a line problem, so Telkom guy came up and went through the telephone jacks etc, declaring everything fine. Typical, the router was syncing while he was here. After he left, the connection dropped.
I thought it must have been the router, so I switched it for my really old Telkom router. That worked fine. No line dropping or anything. That sort of confirmed it must have been the router right? I go an buy a new one, plug it in, and I get the same problem. Line keeps dropping. Have to reboot router, it syncs for about five mins, then connection drops again. I plug my old Telkom router back in and it's working again.
(I just did a speedtest using the old telkom router and I only get 812 kbps on a supposedly 4 meg uncapped line. Could the problem be at the exchange? The old telkom router will only connect at lower speeds anyway, and the new routers try to connect at 4096 so the line keeps dropping? )
Hi all
