Hi ouens,
So this morning I went and got the rear pads fitted. The ones that came out were 99.9% finished!:erm: I asked the guy after he put the brakes on to try and wiggle the wheel to see if there's any play that will give away the signs of wheel bearing damage. NOTHING! I was so happy! I drove off with my new Ferodo pads on...and guess what, no shoo shooo shoo shoo shoo sound...for about 1km!
The brakes started to catch on the disc and almost slow the car down! It took extra revs just to ge the car up to speed...so they were definately catching more than they should. I think the piston was at the set position for the old pads...its self adjusting, so with the newer pads the guy just moved the piston back to accomodate the new pad...but it seems the piston did not adjust at all or is probably still adjusting???
http://www.zeckhausen.com/bedding_in_brakes.htm
Going by this guide, I think I F'd the brake discs up...as previously I did some spirited driving and then immediately washed the car while the brakes were still hot...stupid mistake I know...I think that messed the discs up...I'll follow this bedding in process lunch time...I think it'll work.
I took a quick blast(so wrong) and then off to work, wasn't even 7km from my work, I parked the car...at 12 I'll be heading out for lunch so hopefully then the brakes would have settled into normal position. We know now its not the wheel bearings but the brake pads rubbing against the disc...will the brakes self adjust with some more driving, and Ms. Daisy driving?
Your thoughts.
Your thoughts.
