**Reboot Blackberry Without A Battery Pull**
Zarathustra
South Africa.
If you would like to reboot your BlackBerry without performing a battery pull:
Simultaneously press the [alt] [right shift] [del] buttons & wait for a second or two for the reboot to start.
I did that once and found it doesn't gracefully shutdown .... I lost all the credit I had built up in Poker! Alternatively, there is a free app called QuickPull which I usually use when I want to force a reboot.
Mine seemed to have worked wonderfully. Thanks for the tip, definitely better than the manual pull.
I also tried QuickPull before and found that it wasn't working all that great for me.
