Cat s60
Cat s60
firstly.
there is no Waterproof.
there is basically splashproof. understand what the IP68 ratings mean so you dont get into a difficuilt position because of it.
are you looking to go deep sea diving wiht your phone? then the CAt is the option, and you take a knock on specs to get the higher water resistant rating.
but if you just want to be able to walk in the rain with your phone out. there are 3 options that can compete with the 3T in specs.
the Sony Experia XZ ultra
the LG G6
and the Samsung S8.
right now I am comparing those three and the Huwawi P10 to see what I will be upgrading to. its between the G6 and the S8 for me. and I am not a Samsung fan at all, but I will get the best phone of the year if I can.
yes i do understand the ratings. i meant something with an IP68 rating. i don't plan deep sea, but just normal swimming/snorkelling/general underwater , just for the kids.
My contract has expired and i'm also looking at options. Coming from an Xperia Z3 which served my 'waterproof' purpose. For some reason, dont want to look at Sony again. Not Samsung fan either.
General
OS Version: Android 6.0
CPU: MT6750T Octa-core
GPU: Mali-T860-MP2 650MHz
Processor Speed (max): 1.5GHz
RAM: 4GB
Internal Memory: 64GB
External Memory: Support up to 32GB
Display Size: 5.0 inch Corning Gorilla Glass 3
Display Resolution: 1920x1080
Touch Screen: Support Capacitive
Multi-touch: Support 5 Point
Frequency: 2G: GSM 850/900/1800/1900MHz, 3G: WCDMA 900/1900/2100MHz, 4G: B1/B3/B7/B8/B20
IMEI Number: 2
GPS
Bluetooth
Wi-Fi: 802.11 b/g/n
FM Radio
Google Play
Sensors: Gyroscope, Magnetic field, Proximity, Light, G-sensor
Gesture Sensing
HotKnot
OTG
Fingerprint
Mic and Speaker
Built in Battery
Battery Size: 3500mAh
Continuous Talk Time: up 14 hours
Battery Standby: up to 80 hours
Charging time: about 2.5 hours
8 Megapixel Front-Facing Camera + 13 Megapixel Rear Camera
Video Resolution: 640x480 Front / 1920x1080 Back
Waterproof Rating: IP68
Ports
2(4G/WCDMA/ GSM) SIM card slot – 1x Micro sim + Nano sim or 1x Micro sim + 1xMicro SD (Note: Nano SIM and SD card cannot be used together)
TYPE-C
3.5mm Audio Jack
Languages
English, French, Spanish, Russian, German, Italian, Portuguese, Japanese
Media Formats
Video: MP4, 3GP, AVI
Audio: MP3, WMA, WAV
Graphic: JPG, GIF, PNG, BMP
E-Book: PDF, TXT
Dimensions
Main Product Dimensions: 153x 79x 12mm (L x W x D)
Main Product Weight: 250g
Package Contents
Phone
USB Cable
Power Adapter
User Manual
I get that. wife had a Xperia Z, best Friend had a Z2C that I used while my G4 was being repaired for bootloop.
right now, the top 2 options are the S8 and the G6.
and it is going to come down to personal preference on the two.
right now I am leaning more towards the G6. but I am waiting for the more in depth testing with production models to be done by my favourite youtubers before I make my call.
Cat s60
^^That
I wouldn't mind that phone at all...especially the IR camera that comes in handy when we do engine commissioning and have to check for hotspots on cable joints.
LG G6 is enticing, i just dont know the LG brand, phone wise. Never used one, never knew anyone who did. So not sure about it.
For me the Samsung S8 is OK, but not a Samsung fan and price is ridiculous.
they have learned a lot from the bootloop on the G4
Did they learn to take accountability for their flaw?
Because even now, no one is willing to do the repair free of charge as far as I am aware - re-actively or pro-actively.
no. you are being kinda silly here.
MTN repaired my phone free of charge, my wife's phone free of charge and my best friends phone free of charge.
Vodacom did another friends for free.
and Telkom told you to take it to LG smartlabs.
and I know a few people in the G4 thread on here took their phones directly to LG smartlabs.
no idea why you are raging so hard, from where I am standing, the G4 bootloop issue was handled badly in the beginning and then solved, new motherboards were shipped and there has been no issues that I know of.
maybe you have a different story, but to me you are just sounding a bit sour due to the bootloop. and that is understandable. how do you think I feel when all of my friends ended up getting the G4 on my recomendation and then the phone going into bootloop?
did you post in the G4 thread?
I don't think I am being silly at all - I think you are trying to dispel that there is an issue to fit your beliefs.
A big company such as LG should issue a recall and take the financial knock.
Under warranty - of course it is free.
Outside of that - I have a family member who gave up the phone (left it at MTN) after being told it would cost R2000 to fix - around December 2016.
I am also aware of a high number of G4's sold on Gumtree.
I have said there is an issue, and LG handled the issue. there is no need to recall all the phones, just because there is a quality issue on 15% of the mainboards in production. and they fix the problem as soon as it comes up..
