Reduced speeds with F-Secure Dome
Rohlux
I have recently installed F-Secure Freedome on my pc. This is the result:
Telkom LTE
With F-Secure Freedome NOT active
Download Speed: 49710 kbps (6213.8 KB/sec transfer rate)
Upload Speed: 7755 kbps (969.4 KB/sec transfer rate)
Latency: 15 ms
Jitter: 4 ms
2017/02/26, 8:10:22 AM
With F-Secure Freedome active
Download Speed: 11203 kbps (1400.4 KB/sec transfer rate)
Upload Speed: 6358 kbps (794.8 KB/sec transfer rate)
Latency: 405 ms
Jitter: 5 ms
2017/02/26, 8:17:22 AM
Anybody else had a similar experience ?:confused:
Uninstall it. You don't need that crap.
Install Microsoft Defender if you want something.
Install Adblock
Don't install Flash Player. (use Click to Flash if you absolutely must have Flash)
Don't install Adobe PDF (use a 3rd party viewer)
Don't install Java
Thats 99% of your attack vectors handled, and your Windows computer won't work like molasses.
You need java for the bank and Sars and a fee other sites as well so don't uninstall it.
As for f dome delete that crap.
Avast is good enough.
Thor187 and Isheed_cn
Yes, I'll uninstall Freedome. Thank you for the advice and alternatives.
