Remote desktop not working over VDSL
Rouxenator
Dank meme lord
Stellenbosch
This is a bit of a weird one.
In the past I have always been able to VPN to work and then RDP onto my workstation from home, either on my PC or on my Android phone. Recently I found that when I do that the screen is just black when I do a RDP connection and the I get an error that it can't connect.
I have tried with both Afrihost and Vox accounts. It works on my phone when I go via Vodacom (wifi off). It also works from my parents place, they are on Axxess ADSL.
So I am not sure if it is a router thing or because I am on VDSL? Router is an Asus DSL-AC52U.
any tips?
So I did the ping thing, maxed out 1464, added 28 and what do you know, that is the MTU of the router? Or should I ping the VPN address instead?
Don't if this helps but we've been using 1472 MTU on our IPCop IPSec VPN tunnels forever and never had a problem.
I am connect to the VPN now, largest packet I can ping my workstation with is 1372, how can I tell the VPN connection or RDP to use that packet size?
You will need to make that change on your router's WAN interface I think. What router do you have?
Asus DSL-AC52U, everything works fine so I am trying to get remote desktop to use a smaller MTU
Code:
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>netsh interface ipv4 show interfaces
Idx     Met         MTU          State                Name
 24          25        1400  connected     MiX STB
 14          25        1500  connected     Ethernet
  1          75  4294967295  connected     Loopback Pseudo-Interface 1
So the VPN connection is set to 1400, not sure if that is good or bad?
On the machine from which you are trying to set up the VPN. Can't see at the moment why a change in service connection should have impacted on a working VPN. More to do with matching the PC and the router surely? One should be able to use a smaller MTU than the connection can handle?
Yes ja I was reading the article in the link which states make the change on the router, that's why the "I think" is in there :)
Smaller - yes.
Bigger - and you get what Rouxenator is experiencing.
Code:
Make it 1354 and try again if it's not working on 1400
Tried 1354 and not luck. I wonder if I should try something low like 600.
Edit : 600 also did not work, I think this could be another issue, not MTU related.
I just connected a 3G USB dongle to the router and made that the internet connection, everything works fine. But now back on VDSL - nothing.
Just for interest sake, what it the MTU size on the Asus router under the PPPOE connection settings? By default it's 1492 according to their documentation
