Remote for HTPC and XBMC
Bionic
Deep in the valley, Midrand
Hi,
I have an HTPC that runs Windows 7 and XBMC. I dont have DSTV and only use this for media. I current have standard wireless peripherals but find it cumbersome to use especially when the visitors arrive.
Please can someone recommend a decent, not too expensive remote with mouse support. I must be able to use the mouse to navigate in a browser.
Thanks in advance
Thanks. Will need to find reviews on them. What about Harmony?
I have two Logitech Harmony remotes, they work well but it doesn't seem like anyone sells them anymore (locally at least)
He'd still need the IR dongle won't he?
Flirc is a usb IR receiver that translates any button press into any keyboard or Windows media remote command. So you can teach it to use any remote. The interface is fool proof, and it just works. I use my TV remote's spare buttons to control my media centre.
Looks great. Hows does the Gyroscope mouse feel. Will the SO except this :)
It works great. Just point in the direction of the TV and small wrist movements moves the cursor like a mouse would. Only the click to hold and scroll needs getting used to.
