Remotely reset power plug
Sl33py
East London
Hello
I wantto be able to switch off or reset the power to a ADSL Router from time to time. I fisrt thought to get a POE Smart Switch with a POE ADSL Router but cant seem to find one.
I know you get GSM Switches and "Smart" plugs so I want to find out what people are using to reset plugs remotely
I Have 2 ADSL Lines there with 2 Routers in fail over so I can get access to the network just not fix it.
Thanx
gfmalan has got it - GSM Mini Commander will do it, nothing extra needed. You can also set it up to warn you of power cuts etc.
There are some cheaper GSM options available but you have to be sure they are cleared with ICASA.
Look up Qwikswitch, A South African based company in Cape Town. Products available from Builders Warehouse and other outlets.
Control anything from a light to battleship remotely via the "Internet"
