casspir Active Member Joined Mar 8, 2011 Messages 88 Reaction score 0 Mar 25, 2011 #1 Guys, Small boo-boo. How do I remove (uninstall) Parallels and Win 7 as a virtual machine? I cleared out old data files and in the process I must have removed/moved virtual machine files. Regards, Kinnie
K koffiejunkie Executive Member Joined Aug 23, 2004 Messages 9,769 Reaction score 1,008 Location Australia Mar 26, 2011 #2 I'm not sure I understand what you're after. You say you want to remove Parallels and your Win7 VM, but then you say you've removed the files already?
casspir Active Member Joined Mar 8, 2011 Messages 88 Reaction score 0 Mar 26, 2011 #3 KJ, Dont worry about that. i got it sorted. What happened is that I moved files and in the process included the VM. Got that sorted and deleted. New VM installed and all working well. Quite happy now.
