Renault Clutch Stuck?
Pho3nix
The Legend
On the toilet
Hi guys,
Moms Koleos seems to be having an issue with the clutch, almost as if it isn't getting disengaged as when you drive it.. it sounds like you are still depressing the cluth pedal.
Does this sound possible? Feels very different from a clutch that's kaput.
Does anyone know a decent Renault specialist in the Gauteng(Randburg) region?
Google says there's only 2 in your area. Renault Northcliff and Renault Randburg.
13 Malibongwe Dr · 011 792 3114
Open until 17:30
16, Beyers Naudé Dr & Monkor Rd · 011 219 8000
Open until 17:00
Warn clutches start slipping or upon complete failure don't engage at all. A clutch is simply friction material that allows the transmission and engine to lock together.
If it doesn't do that anymore it is "kaput"
What does that feel like :p
Open until 17:30
Open until 17:00
Looking for non-dealer's prefereablt but I appreciate the assist.
Have you Tried pumping the clutch pedal several times I think this car's clutch is hydraulic my Megane is of that I know.
