leonb
I'm planning some renovations to an existing room (5m x 13 m) which is currently underutilised. It used to be a tv/playroom for the kids. The plan is to convert it to an ensuite bedroom (one side) and a TV/braai room (other side).
There are no major structural works, only the internal walls to separate the rooms, and breaking through the existing walls for new windows and doors. New tiles throughout, etc. It also need a 40m underground sewage line to connect up with main line. The plan has been drawn up and ready to submit, but I'm first getting some quotes from builders to check costs.
The quotes are ridiculously high (in my mind anyway), in the order of R400k I'm considering project managing this myself and getting small subs to do the work, i.e. bricklayer, tiler, electrician, plumber.
The actual work I will be able to manage, but how does the legal and regulatory stuff work? Like the municipality, building inspections etc.?
Any general advise if I decide to go this route?
