Replacement for my Samsung 51E550 Plasma
Badprop_za
Die Poort!
So, some of my possessions got redistributed (unwillingly I may add) to the more alleged "needy".
While waiting for the insurance claim to be sorted, one of the items that I need to replace is my plasma. I have no idea what the assessor will regard as a suitable replacement TV. What will be your views in terms of model range that would be regarded as being on par with the plasma?
Let's try and not get into the Plasma vs LCD / LED (mine is better than yours) debate. :)
Uses currently is:
- Streaming (Showmax, Netflix, YouTube)
- DSTV (Mainly sports)
- Xbox One Gaming
Usage is about a 40:40:20 split in the above order.
Get a 55" UHD ... Netflix is very nice on it. Sport will also benefit.
My budget is going to be around the R15k mark. Which UHD would you guys recommend?
I would have loved something bigger that a 55", but budget is not going to allow it.
