Henry.de.kock
- Oct 31, 2014
Good day all.
I recently had an issue where I could not get power coming from my battery/inverter. I contacted the people that installed my system, and they told me that it seems like the inverter got damaged and it has to be sent away for repairs. I have a RCT axpert max 8kv 48v inverter. Now if I look up the fault description in the manual it states F11 - PV over voltage, and F12 - DCDC over current. I did not know what any of that meant, but the installer said the inverter got damaged. Against my better judgment I was convinced to open the damn things bottom panel, and lets just say, put a screw driver where it does not belong. Yes I know I should not have listened to the person and do something that I have no competency to do, but what is done is done.
I got some one else to come and assess the situation and they picked up some other issues on the installation. Bottom line is the inverter will need to be sent away now for repairs, but it can take up to 3 weeks, and they cannot tell me what it will cost to repair it before they assessed the damage. So my options is take the chance and send it for repairs and hope it does not cost as much as a new inverter, or just buy a new inverter and write the old one off as a ID10T error.
Buying a new one comes with its own challenges since I need to get one that will be compatible with the battery (Narada 150ah 48v) I have, and lets be honest here, I clearly have no expertise to trust myself to make the right decision. So I come here to ask the smart people what would be my options for inverters (what is recommended compatible inverters), or should I take the chance and send the old one away for repairs and pray for the best?
