Replacement remote for Sinotec TV
zll
Anyone know if I can get a generic replacement remote for our Sinotec TV? Most of the remote works, just the on/off switch is dying. You have to hold it down for ages, compared to all the other buttons which you can tap and work instantly.
Take it apart and clean it with isopropyl alcohol
  • Like
Reactions: zll
Not sure if it has been mentioned but clean the contacts on the CB with isopropyl alcohol :sneaky::sneaky:;)
  • Haha
Reactions: zll
Depending on how old your TV is, you could just look for a Skyworth replacement remote, similar to this one:
  • Like
Reactions: zll
just buy one from SinoPrima or now known as Skyworth .in midrand ,if in jhb just go collect it
  • Like
Reactions: zll
Universal remote - should support your TV - not sure what a replacement would cost - this is R300
  • Like
Reactions: zll
This is cheaper
