Return aimflow on pool pressure low
zakslaher
The reurn line through my aimflow of my pool pressure is extremely low.
Suction is good. No leaks or air from weir to pump.
I have solar panels. Any help
Is that the solar panels that heat your pool.
Was it always so low or only after you install in the panels.
Don't you have a bypass tap, to bypass the solar panels.
Is your solar panel thick enough to let all the water through.
is there not perhaps a blockage.
Is there no air bubbles at the pump weir.
Appears you may have a leak.
If there are notable air bubbles coming from the aim flow suggests air in the system.
