Rip DVD - how to ... ?
Dolby
How would I go about doing this, yet keeping all the menu's etc ?
In the past, I've simply ripped the movie file and that's all I need - but with music DVD's I'd like the ability to select by song.
1. Install AnyDVD
2. Install Deamon tools
3. Install Alchohol120
4. Install DVDShrink
5. Make an image of the DVD on your PC with Alchohol120
6. Load image into Deamon tools
7. Use DVDShrink and open the virtual dvd
8. Do whatever is necessary to fit onto DVD
9. Burn result with nero etc.
dvdshrink works nicely, or currently i use anydvd with clonedvd - and 22-30min later you'll be sorted
The DivX Pro software can also do that. Not bad for $10.
How cool would it be for all of these program authors to join forces and create one mammoth DVD ripping software? :/
I'll check that out now ...
So many of these things require 3 different programs ... that one rips it takes away Macrovision, that one transcodes to XYZ, that one does something else that the others don't ...
Thanks,
