Route sentry problems
crysis
Location Location
Hi,
I am having problems with route sentry. Since yesterday, every time i open it, (and obviously it opens the dial up/raspppoe connections) I just cant access the web. As soon as i close it, and disconnect my local, it works fine. Or vice versa. Im not capped, and it was working fine till just yesterday. Can any one help?
get hold of stonecold on the SAIX SGS forums... he knows a bit about route sentry
So your international works only when you disconnect your local connection and close RS?
Yes, and the same with the local. It also works if i have just turned on my computer, and have not opened RS. But when i do open RS, i will have to close it, and disconnect either one of the accounts before i can use the internet again. (or i get the same "server not found" error.
Did you create both dialup accounts using the RASPPPOE protocol and NOT the Windows one to create a "broadband connection"?
Try clicking 'set up routes now' in RS after both are connected and see what happens.
Have you gone into the setting where you tell it 2 connections can be opened?
