I have a local and an international account running through route sentry. When I type in ipconfig I get 2 different settings. One for local and one for international. I have tried both of these to no avail.
I have the same problem>
The only thing that works for me is if I uninstall my Virus protection(Bit Defender) then
login into the router management with 10.0.0.2. ,then re-install the virus protection.
I was told it has to do with my firewall.
Hope it helps.
It does not matter if you are using 1 or 100 accounts with or without routesentry, the ipconfig command will Show you what you need to know. Look for the "Default Gateway" of the "Ethernet adapter Local Area Connection". This should be 10.0.0.2. If your cannot access 10.0.0.2, then your firewall could be blocking this. My AVG asked permission the first time I tried logging into 10.0.0.2 afaik. Try temporarily disabling this, or turning the "learn" mode of the firewall on (like in Zone Alarm).
